CPU Temps question
Bromin327
53
Hey guys...
I have a 4790k with a H55 water cooler on it and it is running at 65C at 40% load...is this even okay? i just rearranged my fans in my case and it became noticeably higher than before.
Ideally, I would use two 140mm in front as intakes.
120mm will do. Yate loon 140mm fans cost about $8 each if you want more.
If all your intakes is in one place and filtered, your case will stay cleaner.
I am not a fan of aio coolers, but since you already have one, I would mount your H55 in the rear, exhausting out.
If you install any more fans, you will tend to draw in unfiltered air from adjacent openings.
I have the NZXT s340 and i have two Corsair AF120s in the back and a Nzxt stock cooler on the bottom front and the h55 with stock fan on it above that
