I bought this laptop back from 2016 , ASUS X455LF , the specs is not really that good for gaming .
Specs:
i5 - 5200U 2.2Ghz (2.7 Ghz)
Nvidia 930m
8 GB Ram
before thermal paste was reapplied my CPU temps never above 90 Degrees on CS:GO in low graphics settings , my GPU same as cpu temps which i concerned
and after thermal paste is reapplied my CPU temps always reach above 90 Deg on CS:GO on 30 Mins to 1 hour of gaming even in low settings, while my GPU temps is always below 70 deg
what makes difference here is i can now play csgo in higher resolution, because there is no difference in FPS nor in low set or high set
in GTA 5 however , my cpu temps always reach maxed to 96 degrees overtime, when i alt tabbing gta 5 , cpu temps goes down to below 70 degrees constantly without degradation hmmm...
i tried to lower my cpu performance to 85% - 99% and its turns out good . my fps is stable and my cpu temps have constant below 75 deg , but i'm still worried that i might damaged the cpu after reapplying thermal paste, because even in turbo boost on, my cpu temp never reach that high
While idle my CPU in 38 Deg and GPU 40 Deg
my question is :
excuse me for my bad english , hehe
Specs:
Nvidia 930m
8 GB Ram
my question is :
- After seeing my gpu temp is get decent while my cpu is getting worse , am i damaged the cpu ? or just bad for applying thermal paste?
- if because the thermal paste, will my cpu dying soon after ?
- Should I reapplying again on my cpu , or just leave it be?
- Does MSI afterburner have 100% accuracy for giving info about hardware temperature?
