CPU Temps Rise and Drop Dramatically
ghost9727
7
Running LinX stress for 20mins and during the test I notice the temps on Real Temp of my CPU are not really stable. They go anywhere from low 60s to high 90s,100. For the most part it stays in the range of 60-80 but there are instances where it will be in the 90s for maybe 3-4 seconds. I was wondering if that was a normal thing?Also overclocked to 3.9Ghz
Specs:
GIGABYTE GA-Z87X-UD3H LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866
Corsair H80I Water Cooler
i5 4670k
Fans are running properly and the pump temperature on corsair link shows that it's around 26C. I've reseated the heatsink and made sure that it was properly seated and still no difference in temperatures.
What application are you measuring temps with? Use the software that came with the motherboard, and review the temps in the BIOS and see if it's fluctuating.
90 is way to hot. That could damage your CPU.
Make sure you put the thermal paste on correctly
