Its set on turbo boost. 4.6 on single and 4.3 on multiThose temps are great nothing to worry about tells you that your cooler is doing its job! What speed is your cpu set at?
Im using cpu max for stress test with avx if im right this test is from CPUID.Your cooler is doing its job and your temps good so everything seems to be fine.
Those temperatures are well within operating temperatures. If the CPU is over 90 degrees Celsius that is a problem.My cpu is i5 9600k and im confused if my temps are good. Im running without overclock and my temps are 27-31 idle and 58 - 60 under 100% load. When im playing Pubg dont go above 55. I want to know is my system running properly with this temps.
If you check above my reply for the tool im using for stress test you know if its good?Those temperatures are well within operating temperatures. If the CPU is over 90 degrees Celsius that is a problem.
When im playing the difference is the temps spikes 42-47 on 60-70% and 50-55 on 80-90%I use CPUID CPU-Z to do my stress test and its perfectly fine it just stresses your temp to max but when playing games your temps will be diffrent then what stress test shows!. Your gaming temps are pefectly healthy!
Yes those temps and useage is good nothing to worry about!When im playing the difference is the temps spikes 42-47 on 60-70% and 50-55 on 80-90%
Thanks for help and yours reply 😊Yes those temps and useage is good nothing to worry about!
I know Aida64 is a good stress tester for the CPU. It is free for 30 days. Make sure when you stress test the CPU, ensure that the top 4 check boxes are checked, which are CPU, FPU, Cache, and RAM. Do NOT check local disk or GPU, they wont help you at all. If you were stress testing the GPU, I would only check the GPU checkbox and leave everything else unchecked.If you check above my reply for the tool im using for stress test you know if its good?
I think i will keep the cpu max its simple and easy to use. Thank for the reply.I know Aida64 is a good stress tester for the CPU. It is free for 30 days. Make sure when you stress test the CPU, ensure that the top 4 check boxes are checked, which are CPU, FPU, Cache, and RAM. Do NOT check local disk or GPU, they wont help you at all. If you were stress testing the GPU, I would only check the GPU checkbox and leave everything else unchecked.
What do you mean by keeping the CPU max?I think i will keep the cpu max its simple and easy to use. Thank for the reply.
sorry i mean i will keep the cpuid toolI think he means about the speed of his cpu clock keep it to the max speed it can run!
