R rafef2003 Prominent Jul 27, 2017 5 0 510 Jul 27, 2017 #1 my cpu is a i7-7700k and when i render videos my cores range from 70_80c is that good
Solution T T ThePixelPuppy Jul 27, 2017 rafef2003 : i mean 60-80c Ah. Pretty much the same as I said. As long as you keep it about >70 then you're fine. But still, extra cooling wouldn't hurt.
T ThePixelPuppy Commendable Jul 26, 2017 13 0 1,520 Jul 27, 2017 #2 Yes. It will run, but don't be doing much else. It may get dangerously close to frying, so maybe get some better cooling. Upvote 0 Downvote
T ThePixelPuppy Commendable Jul 26, 2017 13 0 1,520 Jul 27, 2017 Solution #4 rafef2003 : i mean 60-80c Ah. Pretty much the same as I said. As long as you keep it about >70 then you're fine. But still, extra cooling wouldn't hurt. Upvote 0 Downvote Solution
