CPU thermal issues!
SynQ_THW
77
Hello, I have the processor called 6700k on the ASUS Z170 sabertooth s and i have thermal issues, i get warnings from nzxt cam software that my processor reached 70 degrees. It has happened 3 times! I have it in the case called In win 805c and i think it could be something with the airflow or something similear. I get around 30 degrees idle. Tell me if you need more info! Need help asap! I have NZXT Kraken X61 liquid cooler so im super surpriced about the temps cuase i`ve read that they "should" be around 60 degrees 100% load.
70C isn't something to get overly concerned about. Your temps may be a little higher based on case airflow or ambient temperature. You might set the warning threshold a little higher, 80C. As long as temps stay below this, you don't need to worry about throttling or damage to the processor.
I changed some settings for the kraken and it runs 55-60 degrees full load now, thanks for the help!
