Hi there
I had a very interesting situation here
I have a 9900k
MSI ACE Z390
Crystal 570X
With kraken x52 240ml AIO at auto (intake) from front of the case
At full stock setting
Aida CPU FPU stress test
Was barely touching 86c
I was using cooler master pro thermal past
Switched back to arctic mx-4
Which I suspected it was fake
My temps is above 90c
Not to mention
I at 5Ghz at 1.325v with LLC max voltage of 1.354v
Using cooler master
At cinbench I barely was around the 80c or less
Now with m-x4 I hit a 100c!! Then I closed it
Every thing is checked
I noticed something pretty weird also
AT STOCK all again!
With temperature increase
I see my cpu voltage increase 🤦♂️🤦♂️🤦♂️
At Aida CPU + FPU
1.229v front filter and glass removed using cooler master gel pro at past
To 1.238 filter and glass engaged
To 1.248-1.258 when I used the m-x4 filter and glass engaged🤦♂️🤦♂️🤦♂️
I thought voltage increase temps
Do also temps affect voltage at auto?
Thanks in advance ♥️
I have a 9900k
MSI ACE Z390
Crystal 570X
Not to mention
Using cooler master
AT STOCK all again!
At Aida CPU + FPU
