CPU throttling with temperature of 50c
Feb 27, 2018
Recently the rig I built in August has been suffering from CPU throttling while playing games. My set up is an i5 7500k, a gtx 1060 (6gb), 8gb ram, 650 watt power supply. The temperature of the CPU barely exceeds 50c, but is at 85-100% capacity. Has anyone any ideas?
https://www.lifewire.com/how-to-check-the-current-bios-version-on-your-computer-2617974
5 ways to check bios version. Write it down, then go to the motherboard website and usually under support or downloads you'll see the latest bios versions.
Used to be bios wasn't as important, but with the changes to windows 10 with Creators Edition and other OS updates, it's getting kind of important to stay up to date.
That's an lga1151 v1 mobo, and while it might have been purchased in August, there's no telling when it was manufactured or what bios version is on it. There could easily be 2-3 updates since it was built.
Warning: flashing the bios is not for the faint of heart, you must follow directions exactly, that means no turning off the...
hmmm.
Do you have anything else running? I agree it's a decent build, but anytime you're seeing CPU utilization over 90% you're bottlenecking. Those games provide a balance of reliance of CPU and GPU, so if you're seeing a problem across the board it seems like there must be something else running in the background.
Are you streaming? encoding? is nvidia shadowplay running? Can you confirm FPS is dropping vs something like network lag?
Also, can you fix the problem if you drop your graphics settings in these games (from ultra to high or medium)?
Yeah its an i5, not an i7. It is capable of being run at full capacity and not reaching the fps you want. Especially if you are trying to run other stuff in the background.
It's not throttling if your clock speeds are normal, which they are.
The other issue is the patches Microsoft has been rolling out to fix Meltdown and Spectre issue.
My 8700k went from a RealBench score of 136k to 112k in a week. But I haven't seen any issues while gaming because the 8700k only gets used about 50% in games anyways. Before it was way less even.
Your 7500 (there's no such thing as a 7500k) is a 4-core/4-thread 3.4GHz CPU. It was likely already being used close to max before the updates, so now after the updates it's going to be worse. Let me guess the problems started about a month or so ago?
ShadowPlay might see 5% on the cpu, no big deal. There's other factors at work. Make sure that stupid Xbox DVR is off, that'll kill fps in many games such as cs:go.
Dropping graphics is a 2-edged sword. The game code is all the same, so the cpu is responsible for the same stuff at base, no matter what the settings. The settings themselves are different. The gpu is all about resolution, at the resolution you play at the gpu just has to paint the screen with whatever the cpu sends. If you lower settings across the board the gpu has a much easier workload, so can potentially throw faster fps, which creates higher demand from the cpu, which is already tanked, so no real fps changes. Instead, try selective settings. Drop things like grass details, viewing distance as those are cpu bound tasks, and raise AA, character details etc as those are gpu settings. In nvidia control panel, change physX from the cpu to the gpu. The intent is to put less stress in the cpu, raising its ability, and adding more stress to the gpu, tempering its ability. Overall result is higher fps.
You have a pre-coffee i5. That's 4 cores. No ifs, ands or butts in some games like BF1, pubg, gta5 it's going to take a hit. Those are 8 thread optimized games and running them on a minimum core cpu (4 threads) is going to hurt max potential.
In nvcp you can also adjust settings such as turning triple buffer off, pre-rendered frames to 1 and other tweaks. Most game reddit type wensites/forums have game tweaks settings/patches or at least hints as to what should be set at.
Make sure 2x things are current. Motherboard drivers (especially audio and Lan) and bios. Win10CE can get seriously buggy with some legacy drivers, causing fps loss.
For the most part I agree with the other commenters. One a 7 series chip, you will see a performance hit from the windows sprectre patch. There are different numbers being reported, but 6% seems common (others say "single digit"). Your chip was already on the edge of being processor bound as a quad core. Disabling shadowplay should give you 5%+ back.. I wouldn't worry about FPS counters. Make sure you don't have any non-essential programs running while you are gaming and you may find yourself back on track.
The last thing I can think of that you might check is where PhysX is being handled (in nvidia control panel). If this is set to CPU, it could be adding extra load. You can set it to use your 1060.
Good Luck!
Warning: flashing the bios is not for the faint of heart, you must follow directions exactly, that means no turning off the pc if you get scared. It's a 1 way trip once started, there's no backing out. If any of that spooks you, get someone you trust knows what they are doing implicitly to do it for you.
