• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Pi Cast Episode 3 streams live on Tuesday, August 4th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Catch Scharon on the Tom's Hardware Show live on Thursday, August 6th at 2:00 pm ET (7:00 PM BST). Click here!
[SOLVED] CPU unnecessarily hot for overclocking?
This problem is due to.....
  • You suck at computers
    Votes: 0 0.0%
  • Your hardware sucks
    Votes: 0 0.0%
  • Move somewhere colder
    Votes: 0 0.0%
  • coronavirus
    Votes: 0 0.0%
  • other
    Votes: 0 0.0%
  • Total voters
With my specs (and according to things i've seen online), I should be able to OC my CPU to 5 GHz, or at least 4.8-4.9. I started at 4.7 GHz and increased the voltage on the CPU until it stopped crashing when I run Prime95. This voltage is about 1.3V. When I run Prime95 at this voltage, my cores average about 80-82C, which (according to the guide i'm using) is too hot to increase voltage further. When idle these cores are a tad under 40C. I had LLC on auto during this process. Is this a normal temperature to have @ 4.7 GHz 1.3V for my processor + case + cooler? Is there some problem with my components that's ruining my temperature? Not great with computers so any help is much appreciated :)
CPU: Intel(R) Core(TM) i7-8700k CPU @ 3.70GHz
GPU: GeForce RTX 2070
Cooler: Cooler Master Hyper 212 Evo CPU Cooler w/ 4 Continuous Direct Contact Heatpipes, 120mm PWM Fan, Aluminum Fins, Intel LGA1151, AMD AM4/Ryzen
Motherboard: Gigabyte Z370 AORUS Gaming 7
Power Supply: EVGA SuperNOVA 650 G1, 80+ GOLD 650W
Memory: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz
Case: Corsair Carbide SPEC-Alpha Mid-Tower
