NOTE: THIS IS THE SAME MESSAGE I SENT TO ONE OF MY FRIENDS... EVERYTHING ELSE APPLIES, PLEASE HELP 🙂
Hey man, what's up! I'm having problems upgrading my processor for my desktop PC and William said that you are pretty good with these things.
I'll just cut to the chase: I bought an AMD FX-8120 processor from ebay @ $115, pretty good deal. I have an AMD FX-6100 installed (pretty fast, but the FX 8120 has 8 cores and is significantly faster). I did my homework, so I know that the AMD FX-8120 is compatible with my motherboard.
Here's my current specs:
Motherboard: MSI 760GM-P34 (FX)
CPU: AMD FX-6100
Graphics card: Nvidia GeForce GTX 650 Ti
RAM: 8 GB RAM
So I already tried installing the new AMD FX-8120, and it just freezes at the MSI splash screen. I can't even get into the BIOS setup by tapping the DEL key (i also tried the F2 key). Then, I took off the AMD FX-8120 cpu, and put in the old one that I have (the 6100), and THAT TOO!... It just stops at the MSI splash screen, doesn't get past that.
One of my concerns is that the first time around, I might have put too much thermal paste on the 8120 when I was installing it (I bought it at RadioShack, pack of 2 small tubes for $12). Turns out that I didn't even need to have done that, because the heat sink already had a block of thermal paste on it and was ready to just attach it to the CPU in place. That was my first screw up; didn't notice that at all.
I had never installed a CPU in the past, this is the first time. But I did my homework and I researched to make sure the 8120 was compatible with my motherboard (and it is), and I also watched some YouTube videos on how to actually install the new processor.
Anyway, if you have any ideas, email me back and if you're free later on tonight, maybe we can have a voice chat here on gmail.
Here's the link to the MSI cpu support page, for my motherboard:
http://us.msi.com/support/mb/760GMP34_FX.html#support-cpu
Here's the link to the actual processor I bought:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103961
CPU: AMD FX-6100
RAM: 8 GB RAM
