CPU Usage? Help
StreamingGames
102
So my friend and ai bought similar computer parts, he has a 4790k i have a 6700k. I have an msi z170 m7 he has an asus z97 or something like that. But with my computer using 55 processes its CPU usage was at 14% while he was at 88 processes and was only ar 2%. What gives? Could a low amount of thermal paste of done that? I did the pea method. Idk what it could be..
Process count doesn't really equate directly to CPU usage. You can have 1 process that spans 4 cores and pushes the CPU to max, the same way you can get 100 processes active that barely uses any CPU power.
TL : DR
It all depends on what processes are running
