New build and not sure why my cpu usage is under 20% and yet my cou fan is 90-100% and frequency is very high. Any recommendations on why this is happening?
Is there any way to avoid boosting 1 or 2 cores high and instead keeping all at relative same level?
Until you list your parts it would be just wild guessing that wouldn't be of any help. Also under which circumstances does it happen ?New build and not sure why my cpu usage is under 20% and yet my cou fan is 90-100% and frequency is very high. Any recommendations on why this is happening?
CORSAIR RM Series™ RM650 80 PLUS Gold Fully Modular ATX Power Supply |
Do you mean the windows power plan balanced and high? I think your issue is that you need to set a custom fan curve so that the CPU temps dont cause the fans to go towards 90-100% when its only at 55-65 c temperature.usually in balanced mode not extreme performance
What do you mean when you say:
This is probably because 1 or 2 cores are been taxed at 100%, thats why you see the CPU fan at 90~100% RPM. Your gaming is most likely using only 1 or 2 cores. Those cores are boosting really high and so the temp from those needs to be kept under control and so -> CPU fan goes to 90~100% speed.
