CPU voltage fluctuating when using offset.
refmon
290
Hey all,
I have a 3750k at 4.5 that needs 1.275V. Firstly, the base is 1.120 so I added 0.155 in the offset to reach 1.275V. Instead it went up to 3.55V when under max load instead of 1.275V.
My voltage is also fluctuating momentary when under full load, from 3.55V to about 3.33V. I've never messed around with LLC so its on auto right now but should I try to put it on high?
zebarjadi.raouf
Commendable
Jul 10, 2018
862
You sure you read that right. I would say you fried your chip multiple times if that's true. Intel's max VCore voltage is 1.920v. You can't go above that unless you enable extreme overvoltage.
Use CPU-Z to monitor voltage. Disable all power saving options from BIOS. And use LLC (Load Line Calibration).
If you have set many options under OC page to auto like BCLK mode, Consider manually inputting the stock as motherboard sometimes messes with them.
