Z zayyan.ghani.khalid.samad Dec 17, 2018 12 0 10 Jan 9, 2019 #1 Hi I was wondering is 1.05 volts is fine for an oc from 3.4 to 3.8 ghz in an i7 4770k Thx
Solution RobCrezz Jan 9, 2019 Does it work? You can tell if the voltage is too low, because the system will crash under load.
RobCrezz Expert Ambassador Mar 14, 2013 19,080 99 75,190 Jan 9, 2019 Solution #2 Does it work? You can tell if the voltage is too low, because the system will crash under load. Upvote 0 Downvote Solution
Z zayyan.ghani.khalid.samad Dec 17, 2018 12 0 10 Jan 9, 2019 #3 RobCrezz : Does it work? You can tell if the voltage is too low, because the system will crash under load. It actually doesn’t like in demanding games like x plane 11 and cs go! Thx a lot! Upvote 0 Downvote
