hey guys few days back when i tried to boot my pc it did'nt even post. so i was trying to figure out what was casing it. first i checked psu and it was ok. than i start removing every component of pc one by one and after removing a component i press power button. i repeat this process untill only cpu was left inside motherboard. so in next step i removed cpu and press the power button. in no time vrm mosfet near 8 pin cpu connector start burning. ( forget to mention before doing all this when i try to boot pc without plugging 8 pin cpu connector. at least lights on mobo glows and fan was spinning )
my question is that why vrm not burned when cpu was in the socket and what cause it to burn after removing cpu.
a smart guy on linus fourm told me that my cpu was bad which cause it
specs
r5 3600
msi b450 pro vdh max
rtx 2060
16gb 3200mhz ram
650watt psu
specs
r5 3600
rtx 2060
16gb 3200mhz ram
650watt psu
