CPU Water cooler and case fan set up
NightWolf13
6
I bought an Corsair H55 water cooler for my build but the Mobo I own has only a CPU Fan header and a Case fan header. I have 3 slots for fans. 1 120 mm at the top of the case and 2x 120mm fans at the bottom. I plan to install my radiator at the top and 2 120mm fans at the bottom so was wondering how do I install the pump + the 3 fans. I know the case fan header is always at full speed. Any help would be appreciated :)
Connect pump straight to PSU, it doesn't need any speed corrections. Radiator fan(s) to CPU_Fan header and placed as exhaust. other 2 fans you can connect with a splitter to one CHA_Fan header (i would use them as front intake).
