N n99crawford Feb 1, 2019 1 0 10 Feb 1, 2019 #1 CPU won’t work is the retention plate is on. Tested with the metal bar that locks into place off, and the pc boots normally, but if I clamp it down, the pc will turn on for a second, the motherboard debug light comes on, and it turns off
Solution scout_03 Feb 1, 2019 do you have it in the right position and should not work unclip check the cpu base on board and if you dont have any bent pins on the cpu .
scout_03 Titan Ambassador Feb 18, 2010 30,566 321 107,640 Feb 1, 2019 Solution #2 do you have it in the right position and should not work unclip check the cpu base on board and if you dont have any bent pins on the cpu . Upvote 0 Downvote Solution
