Hi there,
I'm trying to get my CPU pasted 4.5ghz. However it seems like it doesnt work. Now mind you, the computer does not crash or something like that, it simply won't allow me to get beyond 4.5ghz (setting it to for example 4.8ghz in the bios it just ignores that and makes it 4.5ghz)
First I thought my computer was ignoring the 4.8ghz in bios because it wasnt getting enough voltage to set the cpu to 4.8ghz. But even at 1.4v it still doesnt apply the 4.8ghz.
I'm sure it's some sort of power setting in my bios. However I cant seem to find any setting like that.
CPU: i7 7700k
Mobo: Gigabyte Gaming K3 (Z270)
Cooler: NZXT Kraken X62
Temps running at 4.5ghz is 55-60c during a stresstest and 35c during IDLE.
Edit: Seems like the problem is the turbo boost. If I enable it, it will only follow what the turbo boost is set to. If I disable it, it will still follow the last used settings on the turbo boost. Example:
Setting the cpu manually to 4.8ghz, but leaving turbo boost disabled at stock speeds (45ghz) will make the CPU run at 4.5ghz.
Setting the cpu manually to 4.8ghz, and disabling turbo boost will still run the CPU at 4.5ghz because that is what the tubo boost was set to.
If I set the turbo boost to 4.8ghz, and then disabling it OR enabling it, that is what my CPU will run at.
What the heck? I'm so confused.
CPU: i7 7700k
