cpu-z is only showing core speed instead of CPU speed for me?
It's probably throttling down to save power, I'd try running a CPU intensive task and then check again.
Edit: If you don't want your CPU to throttle there are options in the BIOS configuration to disable that feature.
Ok, im going to look for that option in the bios
