I am not sure if this should have been posted to motherboards forum instead...
Ok, this is going to be long so bear with me.
I usually don't shut down my PC, it goes to sleep after 5 minutes of inactivity. That being said, on December 20th after I woke up, my PC wouldn't wake from sleep in the beginning and after I reset, some fans wouldn't turn on until almost all LEDs from motherboard were lit. It turns out my motherboard went bye-bye (Asus z170-a), so I bought a new one Asus prime z270-a. I am mentioning this because I had some thought that my CPU might have been affected somehow as well.
Fast forward to last week. Again my PC did not fully wake from sleep. This time everything was working but I had no display and the Cpu_led in my motherboard lit up, then it switched to dram_led and after some time again switched to cpu_led. I forced shut down and everything was fine but again when it went to sleep, the same thing happened.
Normal shutdown and restart has no indication of problems. While on sleep though... CPU led, then dram led and again CPU led and I have to force shutdown.
Things I have tried:
Removing all overclock and disabling XMP profile.
Using one stick of ram at a time.
Re-seating CPU.
Testing ram for problems.
Unplug and replug everything from my PSU.
Nothing has worked so far.
Any ideas?
My specs are in my signature 100% accurate.
Re-seating CPU.
Any ideas?
