Happy New Year everybody!
I've bought hardware for a new year, but I can not start it. After I install CPU, Power Supply and RAM into MOBO, and after try to turn on the computer - the red CPU_LED light flases for a second, and computer goes to reboot in about 5 seconds.
-all fans are working fine
-the green flash on the MOBO is working
-8pin & 24pin power supplies are connected well
-same situation both in ATX and without in (while MOBO is lying on the table)
-i've done my best while connection RAM - either it was connected in all blue slots, or it was connected just in 1 slot (D1), or it was 4 slots on one side, etc
-all CPU pins are well done, no damaging
the result is one - computer instantly reboots.
i've tried to upgrade BIOS to the last version - no effect ( http://event.asus.com/2012/mb/USB_BIOS_Flashback_GUIDE/ )
after that i've tried to restore bios defaults (cmos reset) - no effect after that at all
All hardware is brand new.
MOBO: ASUS P9X79 (RTL) LGA2011 <X79> 3xPCI-E+GbLAN+1394 SATA RAID ATX8DDR-III
CPU: CPU Intel Core i7-3820 3.6 GHz/4core/1+10Mb/130 W/LGA2011
RAM: Corsair XMS3 <CMX16GX3M4A1600C9> DDR-III DIMM 16Gb KIT 4*4Gb <PC3-12800>
PS: Cooler Master eXtreme Power Plus <RS-600-PCAR> 600W ATX (24+2x4+2x6/8pin)
