Hi, I just bought 2 * 1 gigs of ddr2 pc2-3200 cl3 400mhz Micron off ebay and was just messing around with my computer in preperation for them to arrive when i downloaded a program called cpuz ehich shows you whether or not your memory is workingin dual chanel or not, I found out that my existing 4 sticks of ddr2 3200 400mhz ram are working in dual channel however it said that the max supported speed of each stick of ram was 200mhz. My question is, is this fine and this just means that each channel is running at 400mhz or is it a problem with the motherboard. Say if i had 2 600mhz ddr2 ram sticks running in dual channel woudl they show up in a program like cpuz as two 300mhz sticks. Thanks for your help in advance. Ant.
