cracked lithium battery safe to use?
  • Thread starter Thread starter Deleted member 2707986
  • Start date Start date
D
Guest
i have an old nokia phone and i recently noticed that the plastic on the top of the lithium battery is slightly cracked.
the crack basically look something like this (see red line in photo)
View: https://imgur.com/BcVQRWN
maybe i squeeze the lithium battery too hard, or maybe its because i dropped it recently....in any case, generally speaking, is it common sense to stop using the lithium battery once a crack starts to develop on the outer plastic?
thanks for letting me know.
Oddly enough, my wife informed me, on Thursday evening, that a worker at her office had an alkaline cell vent-off inside her wireless mouse and blistered her hand; so, evidently, other battery chemistries--previously thought to be relatively safe--are also subject to nuking themselves.
But, yeah, never ask anyone if it's safe to use a damaged Li-ion cell or battery. It's not, and nobody would stick their neck out to advise you otherwise--implied 'expert' advise, being an opener to a liability lawsuit.
Well, laptop battery assemblies are generally Li-ions in a plastic case. The plastic of the case can be split, and completely and safely usable; however, once the question is actually posed, the only answer to give is "stop using it". You are the best judge as to whether or not you can live with it.
Yea it felt like plastic and the cell still works, so i figure its not a problem. Its used as a htpc so it is on wall power 24/7.
Oh ya, ANY battery chemicals will have some corrosive effect upon skin contact, they just aren't known to explode or catch on fire like modern LION.
Boeing 787 LION fires incidents.
Airlines nowadays demands that your bag with a LION charger built-in, the battery must be removed as a carry-on, otherwise they won't take your bag, les the bag catches fire in the cargo hole and well maybe too late when discovered.
For the OP's cell, there's no way to tell, so the component is likely best replaced--and cell phone Li-Ions are dirt-cheap these days, so there's no cost disincentive on that count.
yeah you're right, its probably not worth having all 5 of my fingers blown right off my palm over a used phone. it looks like there's a couple of supposedly 'new' genuine nokia battery in undamaged condition for sale on ebay, so i'm going to buy one of those instead and see how it turns out.
i've learnt alot from reading all your posts here, so thank you very much for sharing your knowledge with us and for all your help!
It is safe to replace anything you are not comfortable or knowledgeble with to better asses the danger. That nokia battery has the pouch cell type. Now if the top plastic is cracked it's no biggie since the pouch cell is way below that. But if the battery is bulged and the cracked plastic is in two parts that are now slightly misaligned (noting a momevent of the parts that could damage the pouch cell) or a dent.. well that begins to be into unkown and risky teritory. Better change it, but if just a hairline crack on the plastic due to aging.. idk, it might work fine, but don't if you are not comforatble about it.
Metal casing for li-ion li-po batteries is the king. As the metal is stronger in case of anything, and the standardization involved makes 18650 cells be one of the safest type of Li cells (they have vents and valves in it), and a lot of regulation went into them (unlike pouch cells). Also the 18650 and few other variants are heavily researched since most laptops, flashlights, drills, battery powered tools, electric bikes, scooters, and even cars and buses (tesla uses them) use the 18650 Li cell with this reasearched and tested containter type.
Now the standard 18650 cell is out of the question for a cellphone/tablet battery, but good to know if you have an option between a device with propietary pouch cell or standard 18650battery and variants (like in some laptops with integrated batteries, or powerbanks where both options exist)
