1,25KW and 1,5KW PSUs will work just fine in your rig.
When to think about it, those two PSUs are probably too much for your system. Your system may do fine with 850W or 1KW PSU.
To know how much power your system uses, fill out the Outervision's PSU calculator as best as you can,
link:
http://outervision.com/b/SVDixX
I already put in the components i know. Since i don't know the cooling and USB devices you use, add those too to get more accurate reading. Just click on the "edit part list in PSU calculator" button to add more components and post the result link here.
For best efficiency, it's best when the load on PSU is between 50% to 80% of total PSU wattage.
An example. Here's power draw of my Skylake build with medium OC on CPU and GPU,
link:
http://outervision.com/b/ZYUMdM
Got load wattage at about 481W. Since i have Seasonic PRIME 650 in my system with total wattage of 650W, the 481W is 71% of total wattage of my PSU.
