Crackling noise with every speaker I connect to computer
Zangtechman
Hello,
I've looked to answers for my questions on here and they don't quite relate to my situation. I have a laptop that has an internal sound card. Using just the laptop, I have crackling noise on the speakers. Then when I connect my HT system through my USB external sound card, I get the same crackling noises.
Is there anyone that can tell me what might be the issue? The only significant event with the PC recently was I used a charger that wasn't mine for a little bit. It had no sound issues after that and it has been over 2 weeks since I did that. Other than that, no major software installs or anything.
Zangtechman
No, it is pretty knew. I looked through the problem for weeks and it was a problem within a game. Odd thing is it was happening with any sound from the computer such as youtube videos and songs as well. I changed an option in the game and it fixed the issue for the most part. Thanks for the answer though.
Similar threads
