[SOLVED] Crackling/static noises when PC under too much load. With example linked
Oct 17, 2020
Hey guys,
I have a bit of a problem. I upgraded my PC. I upgraded everything except for the PSU. The PSU is really, but really old. Whenever my Task Manager goes on to High Power Usage for multiple things happening at the same time, my Bluetooth headset the Logitech G933 starts making crackling/static noises. The video is linked below this as an example. I thought it was the USB ports at first but I tried every different port and it's not that but then whenever I used my headset with its cable and not bluetooth this problem wouldn't happen anymore. I also tested it with another headset (cable) and the problem didnt occur. So it happens when my headset is on bluetooth. Could this be because of the high power usage it gets whilst having a very old PSU? 6/7 maybe 8 years old.
View: https://youtu.be/iy0V80a7MYk
example
Chopped up audio like this would be due to either interference or incompatibility preventing the audio bitstream from smoothly getting from the CPU/RAM to the headset. If you have a USB hub or USB extension cable, you could try plugging it there to put some distance between the BT-USB dongle and your PC, might help if the issue is noise from inside the PC messing with the adapter. Inserting a USB hub between the PC and adapter may also help if there is a USB host compatibility issue.
