I have ran the dump file and you can see the full report here:
https://pste.eu/p/8jVN.html
Summary of findings:
About your bugcheck:
"Bug check 0xA is usually caused by kernel mode device drivers using improper addresses. This is either a bad memory pointer or a pageability problem with the device driver code. Examine the third party drivers .
Check the System Log in Event Viewer for additional error messages that might help pinpoint the device or driver that is causing the error. For more information, see Open Event Viewer. Look for critical errors in the system log that occurred in the same time window as the blue screen."
Some things to consider:
I would highly advise you to view the full report above, as this will contain much more detail as to the bugcheck and modules running at the time.
- I believe there is a new BIOS for your board: https://www.msi.com/Motherboard/support/B450M-PRO-M2-V2, you may not want to update this until third party drivers are verified.
- I can't see your LAN drivers, are you using ethernet to connect to the internet? Your board has it's own LAN drivers on the MB website.
- i also believe there may be an update for your AMD chipset drivers
- Did you install the DAEMON tools manually?
Any MB / Chipset drivers can be installed from here:
https://www.msi.com/Motherboard/support/B450M-PRO-M2-V2#down-driver&Win10 64
