Hello,
I own a Dell Optiplex 780 SFF with an upgraded CPU (4 cores) and a small GPU (AMD HD Series 7000 1Gb). 2 Days ago I bought a 4k monitor to connect my macbook pro (usb-c hub), and replace my old VGA monitor.
With the macbook pro I encounter no issue, it works perfectly. With the Optiplex on the other hand.. I connected it via a Display Port cable to the monitor, first all works fine, than I tried to set a 4k wallpaper, computer crashed (never had crash issues), after that I had trouble turning it off, led blinking, fans blowing, I let it rest for the night, on the morrow same problem, led combinations indicated memory issue so I tried remove the ram and tried each bar one by one, nothing changed.
Than I decided to remove the GPU, the computer boots and I can have display via my old VGA monitor. I cleaned up the GPU, put it back, all works (for know I guess).
Still I have a weird issue, Ubuntu is installed in dual boot with Windows 10, when I use my VGA monitor I can see the grub page (Windows being default), when I plug the 4k screen I cannot and Ubuntu starts (instead of W10). So in order to use W10 I need to use my VGA monitor, start W10 and then switch to 4k.
Can all this be caused by a SSD corruption ? Or did the monitor somehow blow up my GPU ? The GPU is definitely weak, so the little lag I have with the mouse or the refresh rate stuck at 30 Hz I can understand, but why would the computer crash ? Can the monitor be 'defective' ?
If it's just a GPU issue I can upgrade to something more suitable (any recommendations ?). But I would like to be sure.
Thank you in advance for your help,
Arthur
Arthur
