The sound came from the speakers then the system rebooted, there's no display. I read from most places it's a RAM issue, remove RAM 1 by 1, clean the ports, replace ram 1 by 1 till it works etc etc but nothing is working.
I recently installed a new 500 psu and an ASUS radeon RX570 (DDR5 4gb) and it crashed after 1 hour of Total War- Warhammer 2
M5A 78L-M Mobo
2x 4gb ram (DDR3)
Is the DDR3/5 memory difference an issue? Is my mobo not compatible with DDR5? User guide says my mobo supports up to DDR3 but for several hours, the system ran super smooth. Did I fry my RAM? Will i need 1x8 gb DDR5 RAM stick and is memory difference an issue?
Sorry to be a bother but I just dropped almost $240 on this PC and i'm extremely anxious about this problem
EDIT: just learned DDR3 mobo's/RAM and GDDR5 GPU's ain't a problem so .....? I'm stuck, no idea
EDIT UPDATE: Retried my last GPU, system boots and is working..... What the hell happened to mynew GPU? Did it just die?
M5A 78L-M Mobo
2x 4gb ram (DDR3)
