Question crashing, event 41 kernel power, no clues
Apr 23, 2023
I'm having an issue where my system just randomly goes black and then reboots absolutely fine, can rule out bios as it is newest for this motherboard, not a CPU compatible issue either , in the event logger there are no events leading up to it it just has the error its self, my power supply is 80 gold and almost double my needed power for the system checking CPU temperatures they are normal 30-50 degrees it only happens when the pc is under heavy CPU loads for 1-3 hours, could this be ram or the power supply going bad or is it instability caused by my slightly overclocked CPU if so can I fix it without reducing clock speed, this is very confusing because of the lack of events before it logs the shutdown error is this common, what is the most likely point of failure. a lot of info hope you're just as confused as I am, if you can help cheers
