Question Crashing help
Oct 17, 2021
4
Computer wont get passed bios without crashing.
Currently have-
Asrock B550 extreme 4
1080 hydro
ryzen 5 5600x
Corsair vengeance RGB pro
Tried different gpu, different ram slots.
Cleared cmos.
Posts but crashes as soon as gets to bios.
Before I replace the motherboard, does anyone have any suggestions?
Thanks.
Oct 17, 2021
4
have you determined that the memory is compatible through the motherboard QVL?
did you confirm that this board supports the 5600X without a specific BIOS update?
what make/model power supply are you using and how long has it been in use?
Yes and Yes
Less than 1 year old Evga 650 w gold Super nova
well the product description states that it does need a specific BIOS update to support Zen 3 Ryzen 5000 series.
you will need to verify that you have that BIOS version or later installed.
also post a screenshot of the motherboard QVL showing your memory module(s) as supported.
Oct 17, 2021
4
yes, have the latest BIOS version.
No, it is not on the motherboard QVL. I thought it was but when looking again, it is not. It did work previously
