hi all, im having a bit of a problem with my core i7 920 and i hope you can help me here....
well, i have a core i7 920 with blc @ 150x20=3ghz, its a pretty small overclock, right?
when i run realtemp 3.5 it tells me that my cpu is idling at 55 degrees celcius. this cant be good, right? whats worse is that when i ran a stress test with prime 95 the temps went up to 90-100 degrees! i have a nexus flc 3000 hsf and the cpu voltage it at 1.175. how are my tempps so high? should i lower the voltage or what? do i need a new hsf or is my cpu f**ked up
