OK, this problem is crazy....
Background:
I have a Dimension 4300, which uses pc133 sdram. It came with 256MB installed and I want to upgrade to 768MB or the maximum 1024MB. There are 2 DIMM slots in this system. I have two sticks of Kingston KVR133X64C2/512 which are "known good." I've tested all the memory in my possession using this PC and Memtest x86 for about 8 hours each with no errors.
The Problem:
As soon as I put 2 dimms in at one time, the computer will freeze solid at the Welcome screen or black screen with mouse pointer. I have tested this several times with all possible combinations. Each stick works if it's by itself in either DIMM0 or DIMM1. I have tried removing the original 256MB and inserting two identical Kingstons. The problem corrects immediately if I remove one stick. Also, the BIOS recognizes everything properly.
Any ideas? :?
Background:
The Problem:
Any ideas? :?
