Crazy Voltage and Temperature
caipirovisk
Please guys, take a look. My computer was reseting a lot, so i installed HWMonitor to take a look.
This are the results... Is this voltage correct? 126 Celsius???
What can i do? i opened my case and put a big fan aimed to the inside of my computer and results are the same.
Print screen in the link below.
http://gyazo.com/a08856a37b2350a434454b2749739772
Thanks for your attention guys.
caipirovisk
Thanks ahnilated!!!!! One less concern!!!
What about voltages?
Are they normal or shall i change something in bios?
There is some config there that there is no AUTO value, about voltage, i dont remember quite well what the name was...
There is LEVEL 1 and LEVEL 2, and LEVEL 2 SWITCH ON.
Level 1 i left on 90 and level 2 i left on 110.
If someone know what is that about, is this config harmless?
