Creative Sb X-Fi Titanium and Microphone Problem
Helltech
Used ot have a SB A2ZS. NEver had a problem with my microphone and the soundcard. Got this new one a whiel ago and never really had a need to use the mic, I was just starting college and didnt' really have time to play games anyway, so never hoenstly tired it out. They came with the Fatal1ty headset so I thought hey maybe its the headset, nope the old headset didnt' work. I've tried every damn sound option Vista has and I don't know what to do.
The headset works fine, just not the mic.
In the Recordings tab of the Sound window in the Vista Control Panal I have 4 options. Microphone FP (the fp is front port, as it says in properties, but I don't have any front port so I have no idea what this is). Then I have Line-In (what I think I should be using) it says its working, but no sound can get through. Then I have Digital-In and "What U Hear", I don't think tis either of those that I'm supposed ot use, but i've tried them both.
So if anyone has had any similiar problems please tell me what you did!
I've recently bought a SB X-Fi titanium soundcard and I'm having the exact same problem. Same 3 options: Microphone FP (wich i don't have) - and I've tried disableing it thinking vista may be giving it priority or something (not really a computer wiz here 😛), Line-in (which it recognizes as being plugged in and processing but no sound goes through) and Digital-in (not using optical so this cant be it).
I know the headset works because I've been using it on my laptops ventrilo so thats out of the question. Checked the microphone levels several times and stil nothing.
Speakers work fine but the mic just wont let me input any sound. If somebody knows the solution to this please help us out!
Regards
Ok I've figured it out. You'll need to access the Creative Console Launcher (Start menu -> Programs -> Creative -> Sound Blaster X-Fi -> Creative Console Launcher). Go to settings (bottom middle of the window) and click the "Flexi Jack" tab. Activate the Microphone option instead of the Line-in. After that check the levels on the recording devices and it should be ready to go.Hope this helps.
Regards, Iruga
Regards, Iruga
Thanks.. Your solution worked perfect. Everything is working fine now. How on earth did you figure this out? I even went thru the users guide over and over and could not find the soution. And low and behold.. you come up with this easy fix.. WOW!! Well bud.. keep up the good work and May God Bless You.
I've had this exact problem for more than an year now, and still haven't managed to resolve it. Please help me, as I can't talk to my girlfriend ( 😍 ) via Skype, unless I use my laptop, which uses its integrated sound chip, nor I can communicate with other team members in Counter-Strike, etc.
I fully comprehend what am I supposed to do... I have to set the FlexiJack mode to Mic-In), but the problem is that... the Digital I/O is totally greyed out! 😱
Speech recognition in Vista doesn't detect anything I say, it just shows some trembling blue sound level under the yellow-green-red box (which in turn is under the Peter dictates to his... text.
Why in the Game Mode is the Digital I/O greyed out?
USE MIC FP
Regards, Iruga
Thanks, worked perfect!
It is almost two years after your post and I have been spending a month with Dell and Creative Tech Support about the same microphone issue. Neither of them had any clue about or could figure out this problem. Dell has been replacing my computer parts (including mother board) and resetting and reloading Windows, while Creative insisted it was a Dell issue. I found your post yesterday and my mic works now. Belated Thanks! (I wish the two companies knew the products they are selling).
Wanna rip blu-ray videos so you can share them or make a duplicate copy for your video collection? With Xilisoft Blu Ray Ripper, now you can convert blu-ray videos (M2TS format) to High-Definition formats (H.264/MPEG-4 AVC, AVCHD Video (*.m2ts, *.mts), Apple TV h.264 720P, MKV, HD WMV, MPEG-2/MPEG-4 TS HD Video) with excellent and unmatchable ripping-converting speed while preserving HD quality. Apart from converting to HD format, it can also convert to popular common-format videos, such as AVI, MPEG, WMV, DivX, MP4, H.264/AVC, MKV, RM, MOV, XviD, 3GP, and FLV. Most multimedia players like iPod, iPhone, Apple TV, PSP, Xbox, Zune, NDS, Wii, or mobile phones support and play these types of videos. Preview blu ray movies, clip the movie, crop movie screen, adjust video properties, or add watermark are some of the features that come with Xilisoft Blu Ray Ripper. Download and try this software out, so you're no longer limited to just blu ray-format discs.
• Rip blu ray discs in high speed while preserving high audio and video quality
• Convert blu ray videos to HD or popular common video formats
• Extract audio from blu ray movie
• Capture movie stills and save as JPEG format
• Edit video by trimming, cropping, merging and adding video effects
Play Blu-ray videos on your multimedia devices
Turn your iPod, iPhone, PSP, Zune, Apple TV into a Blu-ray movie theater
• Blu-Ray Disc Ripper and Converter. With advanced blu ray disc decoding technology, Xilisoft Blu Ray Ripper can rip and convert blu ray (M2TS) videos into HD or general-format video files.
Supported HD videos: H.264/MPEG-4 AVC, AVCHD Video (*.m2ts, *.mts), Apple TV h.264 720P, MKV, HD WMV, MPEG-2/MPEG-4 TS HD Video.
Supported general-format videos: AVI, MPEG, WMV, DivX, MP4, H.264/AVC, MKV, RM, MOV, XviD, 3GP, and FLV.
• Blu-Ray Audio Extractor. You can even rip music from blu ray discs and convert them into popular audio files. Supported audio formats: MP3, WMA, AAC, WAV, OGG, FLAC, APE, M4A, RA, AC3, MP2, AIFF, AMR, SUN AU.
• Blu-Ray Movie Image Capture. Capture movie images with the built-in player according to interval and duration. Supported picture formats: JPG, PNG, GIF, and BMP.
Edit Videos; Add Effects
Trim, crop, merge, split, add watermark, adjust effects to polish your videos
• Crop, Merge, and Split Videos. Users can trim and crop video size; merge several videos into one file; or split one video into several files.
• Add Watermark or Artistic Effects. Personalize video by adding picture watermark or text title; colorize your video by adding special video effects like Negative, Old Film or Snowflakes.
• Exact Video and Image Settings. Improve video quality by manually adjusting display brightness, contrast and saturation.
• Real-Time Preview. To avoid errors and mistakes, preview and compare the original video from the converted video in the built-in video player.
Change preferences to optimize profiles
Set video and audio parameters and create your own output profiles for next use
• Adjustable Output Parameters. Customize video and audio settings such as bit rate, resolution, frame rate, sample rate, codec to correspond with your multimedia players.
• Several Profiles to Choose From. Choose from numerous profiles available for different device types. Set your own preferred settings and save as your own profile for future use.
• Get File Size. Compute your desired output file size with the built-in bit rate calculator.
HD Quality
Quickly convert, take full use of your CPU, save your time, free your hands, and relax you
• Batch Conversion. Convert several files at a time in batches to save time.
• Run in Background. Run converter in the background to do other tasks on your computer.
• Set Action After Conversion. Set an action (shut down, hibernate, exit or standby) after a conversion is done to avoid waiting.
• HD-Quality Video Output, True-to-Life Images. Convert blu ray M2TS format videos to HD formats; preview blu ray videos; capture movie stills.
Output File Format Support:
Video: AVI, MPEG, WMV, MP4, FLV, H.264/MPEG-4, DivX, XviD, MOV, RMVB, ASF, 3GP, 3G2, SWF, VOB, TS, DV, H.264/MPEG-4 AVC (*.mp4), MPEG-2 HD Video (*.mpg; *.mpeg), MPEG-4 TS HD Video (*.ts), MPEG-2 TS HD Video (*.ts), Quick Time HD Video (*.mov), WMV HD Video (*.wmv), Audio-Video Interleaved HD Video (*.avi)
Audio: MP3, WMA, AAC, WAV, OGG, FLAC, APE, M4A, RA, AC3, MP2, AIFF, AMR, SUN AU Format
Images: BMP, GIF, JPEG, PNG
OS: Microsoft® Windows XP (SP2 or later), Windows Vista, Windows 7 Ready
Download (seedfly.com)
http://www.seedfly.com/hs0t8hf2yvp7
i have a problem too...de distace btween de back i/o to de PCIE slot is to small...cant fit in mt Asus Maximus Extreme-z...why...
