Hey my onboard sound card of realtek is not working on my PC.
I need to buy new one.
I am thinking of getting
1. creative sound blaster 3 usb.
Will this be ok or i should I get something else. Looking to get atleast or better than current sound quality from realtek audio which I found pretty good.
Mobo: Gigabyte 85md3h
forums.tomshardware.com
I am gonna be using it with Swan speakers M50.
Looking not to spend too much. And buying is from Amazon India.
Thanks
Question - PC speakers & headphones not detected after system cleaning (Windows 7) ?
hey i was cleaning my system, using a blow dryer. Afterwards mobo is not detecting the speakers through the 3.5mm jack. I checked the speakers they work fine in using my cell phone's 3.5mm jack. i had removed the graphic card, ram and mobo battery. both 3.5mm jack behind and in front are not...
Thanks
