G gritkeeper Distinguished Jun 28, 2010 1 0 18,510 Jun 28, 2010 #1 Hello,i HAVE A CREATIVE WEB CAM MODEL # P D 1030 AND I NEED THE DRIVERS FOR VISTA ULTIMATE 64 BIT OS FOR FREE AND IT IS IN A DELL LATITUDE E 5500 LAPTOP
Solution saran008 Jun 29, 2010 As per the Dell site, your Laptop supports 32 Bit OS only, and drivers a re provided only for 32-bit OS. You can get All the drivers for Vista 32 bit from here! http://support.dell.com/support/downloads/driverslist.aspx?os=WLH&catid=-1&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=LAT_E5500&hidos=W732&hidlang=en&TabIndex=&scanSupported=False&scanConsent=False If you want to change the OS, Select the OS you need from the drop-down menu in that page & get drivers.
saran008 Distinguished Jan 7, 2010 1,992 0 20,460 Jun 29, 2010 Solution #2 As per the Dell site, your Laptop supports 32 Bit OS only, and drivers a re provided only for 32-bit OS. You can get All the drivers for Vista 32 bit from here! http://support.dell.com/support/downloads/driverslist.aspx?os=WLH&catid=-1&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=LAT_E5500&hidos=W732&hidlang=en&TabIndex=&scanSupported=False&scanConsent=False If you want to change the OS, Select the OS you need from the drop-down menu in that page & get drivers. Upvote 0 Downvote Solution
Mousemonkey Titan Sep 3, 2006 59,462 17 92,965 Feb 1, 2012 #3 Best answer selected by mousemonkey. Upvote 0 Downvote
Mousemonkey Titan Sep 3, 2006 59,462 17 92,965 Feb 1, 2012 #4 This topic has been closed by Mousemonkey Upvote 0 Downvote
