Critical hard disk drive error has been detected! Help me Please !!!
fatiher
4
Hello, my computer has a bug like this. What should I do?
Windows Repair has detected a bad sector on your hard disk.
This error may cause the following problems:
Data corruption and loss
Inaccessibility of the hard drive
System errors and failures
Hi bro I found the Microsoft site
Check your hard disk for errors
You can help solve some computer problems and improve the performance of your computer by making sure that your hard disk has no errors.
1. Open Computer by clicking the Start button , and then clicking Computer.
2. Right-click the hard disk drive that you want to check, and then click Properties.
3. Click the Tools tab, and then, under Error-checking, click Check Now. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
To automatically repair problems with files and folders that the scan detects, select Automatically fix file system errors. Otherwise, the disk check will simply report problems but not fix them.
To perform a thorough disk check, select Scan for and attempt recovery of bad sectors. This scan attempts to find and repair physical errors on the hard disk itself, and it can take much longer to complete.
To check for both file errors and physical errors, select both Automatically fix file system errors and Scan for and attempt recovery of bad sectors.
4. Click Start.
Depending upon the size of your hard disk, this may take several minutes. For best results, don't use your computer for any other tasks while it's checking for errors.
I hope that helps you.
