T TitanWulf Reputable Jun 10, 2015 33 0 4,530 Sep 10, 2016 #1 Is it better to use 2 pcie cables to each card or can I just use a single pcie cable which is split into 2x 6+2 pins. If that makes sense
Solution turkey3_scratch Sep 10, 2016 Best to use 2; less heat on the cables and connectors so less resistance so less voltage drops.
turkey3_scratch Expert Ambassador Jul 15, 2014 22,627 9 60,960 Sep 10, 2016 Solution #2 Best to use 2; less heat on the cables and connectors so less resistance so less voltage drops. Upvote 0 Downvote Solution
T TitanWulf Reputable Jun 10, 2015 33 0 4,530 Sep 10, 2016 #3 That's what I was thinking just wanted a confirmation. Cheers Upvote 0 Downvote
