G
Guest
Guest
I bought another ATI 4830 to go into Crossfire with my other 4830.
It worked fine at first time, no problems at all, played a few games and it worked.
But after i shutdown the computer and start it back up again, i noticed that Crossfire is no longer working at Device Manager report's only 1 card is detected.
The second card i bought to go crossfire, no longer heats up, but the fan spins just fine on it.
So i took my first 4830 out and left my second card in it's current slot, i booted up and it works like normal, so i tried my first pcie slot and it also works fine as normal.
So when i put my first 4830 back in to go crossfire, i have the same problem once again.
Both of the slot's work fine on both of the card if 1 is just plugged in, but when 2 are plugged in, the second card no longer works. Please Help!!!!! lol
My specs are >>
AsRock M3A770DE - 1.70 Latest BIOS
AMD Phenom X6 1055T OC 3.5GHz
1 XFX Radeon 4830 - 1 Force3D Radeon 4830
PCIE X16 / PCIE X4
CrossFireX capable motherboard.
My specs are >>
PCIE X16 / PCIE X4
