Cryorig h7 problem
yassa123
46
So when i installed the cryorig h7 1 screw on the mobo didn't allign the hole on the Cryorig h7's xbar when i got 3 in place one wasn't in the hole but when i screwed the 3 others the cooler came down and then i could screw the fourth screw? But i'm scared to actually run my pc. Yesterday i let it run for like 1 or 2 mins and there was just cold air going out of the exhaust fan. and on my MSI B250 Krait Gaming the EZ Debug Leds didn't light up the CPU problem LED. Should i boot it up in the bios? I don't want to break my CPU and yes i followed the installation guide.
you wont break it if it overheated it would shut itself down to protect the cpu
boot straight into the bios and watch the temps for a few minutes
But i screwed the Left under screw then right under screw then right above then i could screw the left above one that won't get in the xbar hole? Did i break my cpu or something? Or can i reinstall it just to be sure but i don't have Alcohol to clean the thermal compound so can i just use the one that already was on the cpu
will check them when i get home and yes lol will the delete that thread right now
