[SOLVED] Cryorig M9i vs Arctic Freezer 34 Duo vs Deepcool Gammax 400
nxnje
44
Hello everyone,
after getting advices about motherboard and cpu, i'm here to ask for a little tip.
I like the Freezer 34 Esports and someone online told me this is a good choice.
But i wanna be sure I cannot save something as in this price range i can find:
  • Deepcool Gammax 400
  • Cryorig M9i.
The freezer 34 esports costs around 39 euros, the gammax 400 and cryorig M9i around 30 euros.
There's a difference of about 10 euros then.
I'm buying a Ryzen 3600 and a B450 Gaming Plus Motherboard, with Ballistix Sport LT 2x8gb 3200c16.
Which would you choose? Which is better of the three?
Thanks in advance.
I will just use the stock cooler first. If not enough, I will try to get a better one.
I have seen people that play with the ryzen 3600 and reach 80 degrees too.
It's just because if i have to replace the cooler than i will have to put out the motherboard as well and it's pretty annoying.
