Dear all,
I'm facing a compatibility issue between my Cryorig R1 Universal and my Geforce GX 1080. First my hardware:
Mainboard: MSI Z170A XPower Gaming Titanium
CPU Cooler: Cryorig R1 Universal
GPU: 2x Palit GeForce GTX 1080 GameRock Premium (SLI)
Installation of the CPU cooler was smooth enough, but now I am facing the problem that the GPU does not fit in the first PCI-E x16 slot. As this is a SLI setup I absolutely have to use the first PCI-E slot. Second problem: this rig is going to be overclocked as high as possible - that's one of the reasons I chose this mainboard. Bottom line: I need powerful CPU cooling as well as the first PCI-E slot. Find below my ideal airflow setup, which now is not possible (the indicated fans are all PWM case fans):
I'm thinking about changing the CPU cooler orientation and case airflow as follows:
I'm concerned about two things:
* Too much positive pressure? In the new scenario I have 4 intake fans and only one (large) outtake fan.
* The CPU cooler takes (presumably warm/hot) air directly from behind the GPU backplate - will this hinder airflow substantially? Will the air behind the GPU be "too warm"?
Please share your insights if you have encountered similar setups and problems - thank you!
