Crysis 3 multiplayer connection issues
bcarb
32
Hi Crysis 3 players
I was able to play yesterday but today I always get "connection to the crysis 3 server has been lost or cannot be established" after multiplayer login.
Anybody else having the same problem?
Firewalls are already disabled.
While attempting to connect, I see the ff. in the lower left of the multiplayer screen:
[ONLINE][PATCH_A_2XP].
I am able to access this [http://editorial.gos.ea.com/Crysis/3/network_test/test.txt]
I got it from this [http://www.mycrysis.com/forums/topic59915]
The flushdns did not work.
How do you debug this? Is there a problem in the servers or is it on my end?
Thanks
im not sure if youre saying you have the same issue??? but also was having plenty games without connection problems yesturday and today, and then EVERY server i tried to join and play on lasted for about 2min of game time then i either got kicked, or it said connection lost... this is BS!
yesterday arvo i was able to join and play full games,
last night however and still ongoing today, i am unable to play through a game of multiplayer, connection always drops.
it has troubles at different points during connection to server, sometimes i cant get to server, others i join a side but game doesnt load, other times i get into game, but short time later its dropped.
any solutions would b great
ok after i posted this my i had 1 or 2 games so im pretty sure its not my side...
In multiplayer menu, make sure it says ONLINE PATCH A in the bottom left hand corner... other than that i really dont know.. let us know if you are able to play or were able to have a game or 2..
also where are you from? and do you normally have connection issue?
i know there are a few connection issues but i never heard of it being that you cant see the join match or quick match
Philippines. I was able to play again for about 2 hours straight then it happened again (can't login). Don't have connection problems, only for this multiplayer. Probably not on my end also. It's just sad that it is very hard to connect.
This is really annoying... now whats happening is that i will be gaming for 2-3 games and it will crash with black screen and whit box saying
"DXGI ERROR DEVICE REMOVED"...
It says that my nvidia driver 314.07 was not working, or failed (or somethng like that). i stop/end the program and it just says that it has successfully recovered???
Australia, and still same issue, although i can get into MP menu screen just fine,
just cannot hold a game, occasionally i can connect to one, few seconds ingame and it boots me, saying connection error, etc...
same as wrekcreation i have latest nvidia drivers 314.07
update:
I currently have v1.0.0.2000 [PATCH_B]
For a split second, I also see "An error has occurred" in the green vertical bar before it shows the red attention: error message "connection to the crysis 3 server has been lost or cannot be established". Anybody know where to check next? Thanks!
I have the same problem(the connection to crysis 3 has been lost or cannot established), I was thinking before my router or the connection with my internet provider but no, I buy a new router and call to my internet provider and they say everything its ok. I start feel frustrated.
