Crysis 3 on 3 Displays NEED HELP!
tomh2234
35
I have 3 monitors all runnning fine with my pc, Its a new build and ive never had more then 1 monitor before.
Im not sure how to play any games using all 3 monitors, the side 2 go black while the middle one is the only one showing the game.
any help would be great!
First, you have to setup 2D surround or Eyefinity in the CCC or Nvidia Control Panel as said above, next, you need to select the resolution you plan to play at in the game. If you are using 3 1080p monitors in landscape mode, you set the resolution to 5760x1080.
And only games that support Eyefinity or Surround will let you select that resolution. Well some will and still not work correctly which in that case just put the game back to 1080p or what ever you would normally play in.
Similar threads
