Question CS:GO FPS Problem
Apr 18, 2019
4
I'm a CSGO player and used to have around 200-250 fps on any map (5vs5 gamemode). About 2 weeks ago something happened and my fps dropped to 130-150 and sometimes i get 80-90 (it hurts because i have a 144hz monitor).I really don't know what happened, i reinstalled windows, i tried to use every single fix from youtube videos, i tried to play on a smaller resolution but i still get 130-150 fps.I used to be able to play on primary monitor and watch youtube on the second one but now i cannot do that because of the fps.
PC Specs:
MOBO: Asus H81M-K
CPU: Intel i5 4460 @ 3.2 ghz
GPU: Gigabyte GTX 1050 2GB OC Windforce
RAM: HyperX Savage 12GB 1600 mhz
SSD: Intel E5400S 120GB
CPU Usage while playing is around 80% but sometimes it even goes up to 100% and the temp is around 50-55 C(stock intel cooler). I really think the CPU is the problem. Please help me :(
wabobthedevil35
Commendable
Jul 2, 2016
28
Hmm that's weird af. Try some launch commands. And as in the CPU being at 50. You could try reinstalling csgo. Sometimes that could help. I will look into it a bit more.
Apr 18, 2019
4
My launch options: -high -novid -threads 4 -nod3d9ex -processheap +mat_queue_mode 2 -freq 144.
Tommorow i'll buy a new cooler and some cleaning products and also i'll try reinstalling. I'll come with an update tommorow.
wabobthedevil35
Commendable
Jul 2, 2016
28
PC Specs:
MOBO: Asus H81M-K
Got any update so far about your csgo issue?
Apr 18, 2019
4
Yes i did not want to post after testing for a few days.
So i changed the cpu cooler it was just a poor intel stock cooler and bought a DeepCool Gammax 300.It is pretty cheap and it does the job.I get around 30-35 C while playing and this solved the problem, i have normal fps now 200-250. Apparently the CPU couldn't handle 50-55 C. It's kinda funny i reinstalled windows, i wasted my time searching for fixes on internet and a 20$ cooler solved the problem.
