CS GO low fps - Gtx 1070 gaming x and ryzen 5 1600
chutzy
4
I have brand new pc but I get low fps in CS GO with these specs
CPU: AMD Ryzen 5 1600 3.49Ghz
GPU: MSI GTX 1070 Gaming X 8GB
SSD: Corsair Force GS 128GB
HDD: Seagate Barracuda 7200.14 1TB
RAM: G.SKILL F4 DDR4 3200 C16 2x8GB
MBD: Asus PRIME B350-PLUS
http://www.userbenchmark.com/UserRun/6286994
Any ideas what's wrong? It says my cpu is low performing, how can it be? 🙁
Thanks for helping.
It does look like thermal throttling. If that's not it it seems like I remember some Ryzen motherboards having an issue where they downclocked the CPU when you tried to overclock but they fixed it with BIOS update. I don't remember which manufacturers boards it was though.
Average bench for a stock 1600 is 82%, your CPU is performing way under par. What's your clock speed show in task manager? temps ok?
hey chutzy, i have exactly thesame problem... that you manage to fix it ? thanks
