CS:GO Low FPS recently
Henry_Huynh
26
AMD-FX 9370
GTX 760 SLI
I used to get around 200-250 FPS in CS:GO but now I only get around 80-110. My temps are great, around 30-40c when gaming. I don't know what the problem is and please don't give me any BS about how 80-100 fps is good enough, I want my PC to run as fast as it can.
Remember that CS:GO is beta testing its players without telling them. That game has many issues with frame rates so the problems does not seem to be with your pc at all. Just gotta bear with it until the next game patch comes in. Neighbors kid used to yell at his pc was so slow when in fact it was network lag. So in kind regard just wait this out.
Well I'm going to give you that crap because as long as you don't lag, don't freeze, don't crush don't have any issues with your damn game except fps drop of 100, then yeah there is no reason to whine and moan if one of the stuff above doesn't happens.
It does lag alot (sometimes dips down to 50 ish) , and every fps counts in a competitive game like CS:GO, if your system used to run faster and now its performance has dropped a lot wouldn't you want to fix it? Don't comment unless its a useful comment, it will save my time and yours.
The reason for my comment above was because you were whining about 80-100 fps, you never mentioned it drops below 60 son. So my first comment was as much as useful as info about your problem you gave us in here(because with things you wrote you just sounded as spoiled kid that whines if it doesn't get same slice of cake that he used it even though he got big one even now as well). So next time try to mention part of "How I really have problem with fps" instead of whining about 80-100.
Now as for solution, since it is only this game you have issues with try this one: http://steamcommunity.com/sharedfiles/filedetails/?id=199958323
Yea they just updated the game and my frame rates are back to normal, thanks for the info mate 😀. It was so frustrating, I just woke up and started the game up and realized that my frames have dropped by a 100 and started lagging alot.
