CSGO Build £450 max
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Hi guys. I need your help to build a desktop to play csgo mostly. I have only £450 so amazon.uk is ideal to buy. Also I need a really small case since I don't have much space. Mouse and headphones will buy separately. I want a pc that would last me at least 3-4 years. I want intel i3 + nvidia gtx 1050 ti possibly( I didn't have a good experience with amd+ati)
the thing is when you type it on amazon it ends up being £600. Please help! I'm gonna buy it today. Also, how could I do with the windows/installation? Should I buy a dvd drive? #help
Thanks a lot guys! your help is very much appreciated.
CPU: Intel - Pentium G4620 3.7GHz Dual-Core Processor (£87.78 @ Amazon UK)
Motherboard: ASRock - B250M-HDV Micro ATX LGA1151 Motherboard (£58.17 @ Amazon UK)
Memory: Crucial - 8GB (1 x 8GB) DDR4-2400 Memory (£60.17 @ Amazon UK)
Storage: Western Digital - AV-GP 500GB 3.5" 5400RPM Internal Hard Drive (£26.61 @ Amazon UK)
Video Card: Zotac - GeForce GTX 1050 Ti 4GB Mini Video Card (£139.99 @ Amazon UK)
Case: Zalman - ZM-T3 MicroATX Mini Tower Case (£25.99 @ Amazon UK)
Power Supply: XFX - XT 400W 80+ Bronze Certified ATX Power Supply (£42.99 @ Amazon UK)
Total: £441.70
Generated by PCPartPicker 2017-10-31 23:54 GMT+0000
you will need a flash drive and a pc to make a bootable win 10 usb install media.
Thanks. I liked it but the processor.
Could you please recommend me a good i3/i5? I didnt have a good experience with my last pentium.
You say i would need another laptop and a windows on the usb?
Is there any way to buy windows cheaper online to install from usb?
Thanks for your help.
CPU: Intel - Core i3-7100 3.9GHz Dual-Core Processor (£91.99 @ Aria PC)
Motherboard: ASRock - B250M-HDV Micro ATX LGA1151 Motherboard (£58.04 @ BT Shop)
Power Supply: XFX - XT 400W 80+ Bronze Certified ATX Power Supply (£42.95 @ More Computers)
Total: £445.74
Generated by PCPartPicker 2017-11-01 13:15 GMT+0000
