CSGO FPS DROP, CPU only using 30% problem?
oskarlarsson220
4
Hey! I can start with saying im really dumb when it comes to PC's and stuff but heres my issue.
In CS:GO I have pretty unstable FPS, even tho I cap it to even 300, 250. Tab in and out take ages, freezes for a few sec and causes more fps drops while ingame again. (Other games are working completely fine with tabing in and out without lagging)
My CPU is around 70-75C while playing CS:GO and uses around 30-35% of the cpu.
Speccs:
CPU: Intel i7 6700
GPU: Nvidia 1060 6GB
RAM: 16GB
Moderboard: Asus H170-PRO
SSD: 120GB SanDisk SD8SNAT
HDD 1TB Western Digital WDC WD10EZEX
Anyone else with a solution or with same problem?
I have tried to unpark my cores which I have heard you dont need in Windows 10? Maybe I did something wrong.
I have also tried the typical launch options solutions but nothing really helps.
Is CPU drivers update needed?
Reinstall Windows?
Bios update? (If so how? Im really dumb..)
It just feels like CPU is not focusing on CSGO, like its just focusing on everything else on the pc while playing except for CS:GO.
about the same, 30-40%
